Anything I've seen here would indicate that a form of liquid chlorine is best, regardless of SWG. Whether it be a liquid shock or bleach (no additives). The only SWG specific chemical recommendation I have seen is to use muriatic acid and avoid dry acid for lowering PH when there is a SWG in place. You'll want a good test kit to determine current levels and monitor your FC levels
