My pool equipment is below the water level. The return from the filter and heater runs to a 3-way diverter valve with an actuator to select pool or spa return. Both returns have a standard ball valve before they run underground. The diverter valve was broken during the last ice storm and the ball valve to the pool appears to be broken, as well. So, I need to replace both.
Has anyone tried using something like this 2" Jet Swet plug in a situation like this?
A pipe freeze kit seems like a bad / high-risk idea so close the the ground. I don't want to dig out this pipe if it bursts.
I don't know the model or size of the return fittings and some have eyelets on them, so plugs aren't a great option. I realize the pool level should only drop below the return jets, but I think I have the same exact problem on the suction side and that will require draining the whole pool and I won't be able to test my fixes (or my equipment for that matter) without filling the pool again.
Is there any other method or tool I can use to somehow stop the water flow to replace the ball valve without draining the pool?
ian
ian
