Pump is back in service.
FC is 10
CYA is 45
Please tell me what I need to do. I am tired (working a lot for COVID relief) and I’m not thinking straight. Thank you
Follow the SLAM Process
With your CYA of 50 (round up from 45), your SLAM level FC is 20 ppm. Raise the FC to that level. Test a couple times per day and raise the FC back to 20 ppm. Brush as often as you can.
Check pH while the FC is at 10 ppm or less. Adjust to 7.2 if needed.
