Balancing Chemicals and Preventing Algea Return
FFPool
3
Dayton, Ohio
I’ve been fighting back on algea growth the past few weeks. I’ve finally got it mostly clear, but I just got my TF-100 kit and am seeing numbers that aren’t great.
Here’s what I have:
TA: 240
Ph: 7.8
CYA: 30
FC: 4.5
CC: 0 (didn’t switch color)
I think I need to lower the TA first. I have 128 oz of 31.45% Muriatic Acid. When I use the calculator it looks like I’ll need a few more jugs of it, and that doesn’t seem right. Should I start with adding the whole jug (obviously following safety measures)?
mknauss
51,246
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Welcome to posting.
From your picture, it appears you have active algae. You need to follow the SLAM Process. No need to mess with TA. Lower your pH to 7.2 and follow the directions in the article.
Reactions: FFPool
FFPool
3
Dayton, Ohio
Welcome to posting.
Thank you! So I have added Ph Minus and will keep checking that every hour to get it lowered.
Do I keep the pump running when using that? I thought that aeration increased Ph.
mknauss
51,246
Laughlin, NV
Fiberglass
You need to run the pump to mix in the acid. You only should have to add it once or maybe twice. Once you get the pH to around 7.2, start the SLAM. The SLAM process is what is needed. A precise pH level is not needed.
