My auxiliary pump will not turn on. No previous problems, and test operations were fine over the winter. No clicks, no sounds, no light on the board, nothing when I push the Aux1 button now. I activated service mode and pressed the Aux1 relay button; Aux 1 LED did not illuminate. Test results on capacitor were inconclusive (limited by my knowledge and my analog meter) so I put a new capacitor in, same result. Next step is to get a T6 so I can pull the cover and swab the contact with alcohol (as an aside, swabbing works wonders for ceiling fan controls) but if that doesn't solve the problem, the ProLogic Troubleshooting Guide says "replace the local display." Any other ideas?
Aux1 runs my Polaris PB4-60 booster pump. Pro-Logic is a model PL-XX-XX.
