C cloudywater Member May 7, 2022 13 florida Pool Size 20000 Surface Vinyl Chlorine Liquid Chlorine Apr 20, 2024 Add bookmark #1 Going to use my basic Pentair inline feeder when I am gone for a week. How many 3 “ tabs and what setting (1-5)? Normally have used BBB method. Thanks
mknauss Mod Squad TFP Expert Bronze Supporter May 3, 2014 58,521 Laughlin, NV Pool Size 6000 Surface Fiberglass Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-40 Apr 20, 2024 Add bookmark #2 Use a floating dispenser. What is your current CYA? Your signature shows you use pool store testing. Not TFPC method.
C cloudywater Member May 7, 2022 13 florida Pool Size 20000 Surface Vinyl Chlorine Liquid Chlorine Apr 20, 2024 Add bookmark #3 45
mknauss Mod Squad TFP Expert Bronze Supporter May 3, 2014 58,521 Laughlin, NV Pool Size 6000 Surface Fiberglass Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-40 Apr 20, 2024 Add bookmark #4 OK -- 5 8 oz tablets will raise your CYA by about 10 ppm. So you will end up at 60 ppm. It will be impossible to add enough chlorine each day with tablets. But you may get by for a week. Fill the floating dispenser.
mknauss Mod Squad TFP Expert Bronze Supporter May 3, 2014 58,521 Laughlin, NV Pool Size 6000 Surface Fiberglass Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-40 Apr 20, 2024 Add bookmark #5 Be sure to have your pH and TA on the high end as the tablets will lower both of those. Reactions: cloudywater
C cloudywater Member May 7, 2022 13 florida Pool Size 20000 Surface Vinyl Chlorine Liquid Chlorine Apr 20, 2024 Add bookmark #6 mknauss said: OK -- 5 8 oz tablets will raise your CYA by about 10 ppm. So you will end up at 60 ppm. It will be impossible to add enough chlorine each day with tablets. But you may get by for a week. Fill the floating dispenser. Click to expand... This is an inline, not a floater; any ideas on a setting for those 5 tabs?
mknauss Mod Squad TFP Expert Bronze Supporter May 3, 2014 58,521 Laughlin, NV Pool Size 6000 Surface Fiberglass Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-40 Apr 20, 2024 Add bookmark #7 No idea. Unless you run the pump 24/7, never use an inline feeder. Reactions: Bperry
