- Nov 14, 2021
- 8
- Plaster
- Pentair Intellichlor IC-40
Owner/builder project. Just got water in and equipment started up two weeks ago. Everything is working fine in manual control, and if I use my iPad everything runs perfectly EXCEPT for starting/stopping the heat pump remotely / automatically from my ScreenLogic system (iPad / iPhone). The heater WILL run and do it's job if I take it out of remote mode and operate it completely from the heater touch panel. I've written this post about 4x trying to figure the best way to convey everything I know, and all that I've done. I typically try to exhaust existing forum posts, research from others, etc before creating a new post. Though that research has helped me solve a ton of other questions, as well as things to try to solve THIS issue, I can't seem to figure the magic combination of things to solve the problem.
So I figured the best way to convey info was to use photos and notes to show what I have done, what I'm seeing, and what I'm thinking. The attached PDF is 4 pages and might be overkill, but hopefully it helps. A picture is worth a thousand words right? My hunch is that I have UltraTemp wired correctly, and menus setup correctly, and the problem is either where I have the RS-485 terminated in EasyTouch and/or I don't have EasyTouch set up correctly.
This pool was a Christmas gift to ourselves. In FL it still gets "cold" .... 45 degrees ... we can at least still enjoy the hot tub in manual mode
For anyone patient enough to help, thank you in advance!!!
