Which brand/model cover pumps are ok to keep in place through the winter? I have a new autocover this year and live in Indy, so it'll get below zero a couple of times for sure. Thanks!
Poolman9, I don't think of autocovers being *meant* to be winter covers, bearing the weight of snow and rain so heavily. Yeah, some do use them so, but it is a bit of a risk to the cover...y'know?
Maddie, we were told that the autocover would serve as a winter cover as long as the level was maintained just below the skimmer- it floats on the top of the water. It's an APC cover, made right here in central Indiana.
Jlayer, that's the same pump we have so good news that it will do the job here!
Maddie here in the central part of Missouri we have been installing and using auto covers for year around use. We have only had one customer to have issues and they could not get it in their heads that they needed to keep the water pumped off. It pulled the track off two years in a row because of that. They finally sold the house new owner gets it.
Getting buried under lots of snow is what seems to kill pool pumps. I now bring in my cover pumps before the first big snow and then put it out once a thaw starts and the ground is showing. Once you get snow on the ground and freezing temps the pumps are of no use and water in the hose freezes and blocks it.
I use the Little Giant APCP-1700 on my main pool cover and this smaller pump on my spa cover.
