Attaching temp sensor in PVC pipe.
just Hey, if it works that's good enough for me!
Hard to argue that. I saw that some of those are pressure rated. Would any generic one be? Or does the OP need to find one for a pressure application?
Would it just clamp to his sensor's housing? Such that he wouldn't need the washer and nut that came with it to hold it in place?
What about the threads? Would half of the sensor (the threaded part) be outside of the gland (and the water)? What would that do to the temp sensing (especially if those threads are gunna get hit by the sun)?
Or are you suggesting he not use the sensor he found and go with a different one?
I'd still trust my threaded PVC cap idea better. The cap is threaded, the sensor would be held in place with threads and nut. If I'm understanding a cable gland correctly, it'd just be the friction of an o-ring holding the sensor in place against the water pressure. An o-ring that is outside, subjected to the elements. Hmmm...
With the threaded PVC cap, all of his sensor would be in the water (except the part of it that doesn't need to be).
What @Darin says... "Cable Gland"
Working great for me. +6 years. No issues.
Amazon.com
Looks like it seals right around the probe itself with compression-type fitting. is that correct? I couldn't tell 'till you posted that it would snug up enough... this looks great and 6 years with no leak is plenty for me.
Correct. It is a compression type fitting. Thermistor goes inside and then just tighten up the nut. All there is to it.
In addition in my case, I used a 2" slip x 1/2" fem threaded sch40 reducer bushing installed at the tee fitting..
If I recall, I picked it up at Home Depot.
Well, it does exist, if you can get it shipped to you and have it show up matching the picture.
Alternative: there are threaded end caps that might also work. This would be useful to later get at the sensor without having to cut out a glued-on cap.
If their on-line spec's are to be trusted, both of these are rated for 150 PSI.
The nice thing about the threads is you could later replace a faulty sensor, or change it altogether to some other brand/model that wouldn't have to be of the same diameter. You'd just replace the threaded cap and drill whatever hole you needed. You really should have a way to get at the sensor's nut, which is going to be on the inside of your plumbing.
I like the flat cap. In my experience threads end up leaking, but it might be worth a try.
Why not just use a thermowell with a 10K thermister with a 1/2" tee you install anywhere convenient? No complicated leak source to deal with. Even SS thermowells are cheap. @Katodude showed me this at his pool... temp diff across the well wall is insignificant and you can trim that out with calibration.
Chris
I'm using a ds18b20 in my application. 10k won't work. If I could use 10k I'd just drill a hole with an oring and hose clamp.
Reactions: setsailsoon
Thanks, I didn't have time to review the total thread. I wouldn't worry about a high quality SS thermowell. I've seen them used for industrial boiler feed water making very high temp super-heated 1500 psi steam. Contaminants are controlled to virtually zero with anionic and cationic beds that are regenerated with strong acid and caustic. If you get any contamination it can easily cause an emergency shutdown that almost always costs $1MM to fix. But everybody has to make their own choices and I get that. Plastic is not very conductive so "calibrating out" the temp difference could be an issue.
Chris
The problem isn't corrosion, it's being electrocuted.
"Not for use in salt water or other corrosive environments. These are not IP rated," from their data sheet. Even a non-salt pool can have up to 1000 ppm from a year's worth of chlorinating. Maybe will work and for $10 worth trying but if it's an electrical hazard... maybe not.
Even more reason to use a pvc thermowell.
Progress update. I used one of those step drill bits to make the hole, which didn't do the cleanest job so I finished it off with a round file and some sandpaper. I suspect it will seal up OK. There is a rubber gasket on the inside.
So I plumbed this loop to send water to my solar panels, but I screwed up by putting the check valve directly over the solar valve, not realizing the actuator would get so close I can't put the valve handle back on. I also think any water dripping from the check valve drops directly into the actuator shaft. Oops. So I will try to move the check valve over where the green arrow is and insert the thermowell tee where the red arrow is.
