- Nov 12, 2017
- 12,647
- Plaster
- Pentair Intellichlor IC-40
Hard to argue that. I saw that some of those are pressure rated. Would any generic one be? Or does the OP need to find one for a pressure application?just Hey, if it works that's good enough for me!
Would it just clamp to his sensor's housing? Such that he wouldn't need the washer and nut that came with it to hold it in place?
What about the threads? Would half of the sensor (the threaded part) be outside of the gland (and the water)? What would that do to the temp sensing (especially if those threads are gunna get hit by the sun)?
Or are you suggesting he not use the sensor he found and go with a different one?
I'd still trust my threaded PVC cap idea better. The cap is threaded, the sensor would be held in place with threads and nut. If I'm understanding a cable gland correctly, it'd just be the friction of an o-ring holding the sensor in place against the water pressure. An o-ring that is outside, subjected to the elements. Hmmm...
With the threaded PVC cap, all of his sensor would be in the water (except the part of it that doesn't need to be).
