Hi All,
End of last year my Aquarite T9 was working fine. This year I'm running into some issues
The issue I experience is that I'm getting both Check Salt and Inspect Cell solid lights after turning on the system.
I can replicate with the following procedure:
I took the cell to the pool store, they have a Hayward specific tester, and my cell passed the test.
No other details other than pass/fail.
While in the test rig, you can see the cell plates, and I could see bubbling coming from the plates.
I haven't had any issues with my control panel in the past.
Any suggestions on what I can do as a next step in troubleshooting?
Any other data I can provide?
Thank you very much!
FC 3.6
CC 0
PH 7.5
TA 90
CYA 24
Salt 3000
Aquarite unit AQR-XL-CUL Serial: 3A1005-1025465
Cell T-CELL-9 Serial: 3E1005-2055603
I've had the cell 5 years, it's older than that though (bought house with pool)
Thanks.
- Turn on the generator (currently set to 40 , same occurs when using super-chlorinate)
- After a short time, I can hear a relay click, and the instant-salt reading starts. (Generating light is on)
- Initially high, it climbs down and steadies around 2900 (sometimes bounces to 3000)
- After about 20s or 30s, the relay clicks off, instant salt level goes to 0 and the Check Salt and Inspect Cell lights go solid.
FC 3.6
CC 0
PH 7.5
TA 90
CYA 24
Salt 3000
Thanks.
