@JamesW
hey could you clarify this any further? I am really trying to figure out my chlorine output and honestly I am not sure from everything that I have found here whether my cycle is 1 hour , 120 minutes or 180 minutes. I was trying to keep and eye on it to figure it out manually and started seeing chlorinator off percentage met when I know that it shouldn't be based on my setting, but "At 60 degrees Fahrenheit, the output is reduced to 20% of the setting." could explain what I am seeing. I haven't seen that in any Hayward p/w I have read or anywhere else on this site. We had a cold snap for the first time and I saw chlorinator off low temperature for the first time yesterday. Today the swg is back on but seems to be not on as long usual. I see chlorinator off percentage met in what seems like 15 mins or so. Does the cell reduce output at a particular water/air temperature? What temperature is it supposed to be totally stopped at ?
Not sure what/if any of the below helps you but put it in anyway:
main software revision 4.30
display software aqua pod r0.97b
rf base software r3.00 id:3867
