Hello all,
I’ve been trying my best to find a solution to this problem for weeks with no success. I’ve watched countless videos, read pages of forums and spoken with a Hayward specialist for days but am getting nowhere.
I have a new AQRS325 with the AQRS3OMNIKIT controlling my swg, heater and lights. I did have a single speed pump wired through HVR1, but was given an older VSP by a neighbor who only used it a year and stored it in his garage. I changed pumps wiring it directly to the breaker and used the pumps controller to set my schedule. The pump is a Hayward Maxflo SP23115VSP and was manufactured in 2017.
I’m attempting to control this pump with the Omni without any luck. I cannot get the pump’s HUA to be recognized by the Omni as nothing shows when going into diagnostics or when editing the current configuration in the wizard, changing the pump type to VSP and trying to find the HUA. As for wiring, I am disconnecting the pumps display panel from the RS485 but using the 4-pin connector. Wires are A to 2, B to 3 and Com to 4 and connected to the Omni’s Comms Bus. Pics were sent to the Hayward tech and they said everything looked good.
The dip switches were originally set with 1 and 2 on, which the tech found odd, but this works fine for the display in standalone mode. Turning off #2 causes a connection error on the display. As instructed in the manuals and tutorials, all dip switches were set to off. I’ve seen and followed the bulletin advising to turn the power to the pump off and wait a minimum of 15 mins to allow the pump to reset. I waited a hour once but seems to work.
Hayward is saying that the age of my pump’s display is too old and I need a new one so that I can scroll in the diagnostics menu and obtain an HUA. My argument here is that the display will be disconnected and wires replaced with the wires going to the Omni thus eliminating the display from the setup . So how is updating the display that is just going to be disconnected going to aid in an HUA being recognized by the Omni?
If anyone has any insight as to how to possibly resolve this I’d be very grateful.
Thanks in advance.
Thanks in advance.
