- May 3, 2014
- 62,725
- Fiberglass
- Pentair Intellichlor IC-40
“He” does not know what he is talking about.got it. Thanks. I may have misunderstood what he said, I know he did say that the cell determines the salt level. That seems correct based on the document you linked. Right?
Thank you. This makes sense. Is a low salt level on the display ever a result of a bad board? Also, does a lower calculated salt level produce less chlorine?“He” does not know what he is talking about.
Hello, below are the results. For the actual salt reading, my salt kit has not yet arrived so I went to 3 different stores and averaged it. They were all between 2500-2900. I know this isn't the preferred way but no choice at this point. Also, the cell was not generating at time of the test as the salt was below 2300 according to the panelBasic AquaRite Diagnostics
This is the basic information we need to know in diagnosing a problem:
Report all diagnostic readings when you..
Move the switch from auto to off and check all of the readings.
Move the switch back to auto and recheck the readings.
Move the switch to off for a minute and then back to auto and recheck the readings.
What are the first seven characters of the cell and box serial numbers?
What is the actual salinity and how are you measuring it?
Correct.Do I flip from auto to off and check and then back to auto and check?
Thank you. Another question. Not sure if you saw this in the thread but after the system shuts down overnight I have to either wiggle or often reseat the display board to get the salt panel to power up. It then stays on al day. If it only shuts down for a couple of hours it is fine, but when off for 5-10 hours it needs some help.Correct.
Instant Salinity/Actual Salinity = Performance Percentage.
Maybe a bad display board or main board.Any thoughts on if this is a bad display or board?
