- May 3, 2014
- 62,717
- Fiberglass
- Pentair Intellichlor IC-40
“He” does not know what he is talking about.got it. Thanks. I may have misunderstood what he said, I know he did say that the cell determines the salt level. That seems correct based on the document you linked. Right?
Thank you. This makes sense. Is a low salt level on the display ever a result of a bad board? Also, does a lower calculated salt level produce less chlorine?“He” does not know what he is talking about.
Hello, below are the results. For the actual salt reading, my salt kit has not yet arrived so I went to 3 different stores and averaged it. They were all between 2500-2900. I know this isn't the preferred way but no choice at this point. Also, the cell was not generating at time of the test as the salt was below 2300 according to the panelBasic AquaRite Diagnostics
This is the basic information we need to know in diagnosing a problem:
Report all diagnostic readings when you..
Move the switch from auto to off and check all of the readings.
Move the switch back to auto and recheck the readings.
Move the switch to off for a minute and then back to auto and recheck the readings.
What are the first seven characters of the cell and box serial numbers?
What is the actual salinity and how are you measuring it?
Correct.Do I flip from auto to off and check and then back to auto and check?
