PlayN4Keeps
8
Murrieta CA
My AquaLink RS8 is only programmed to only turn the primary pool pump on. I’ve noticed that’s been turning on other Aux (lights and waterfall) ports. I switched off the power breakers to see if it would reset it, but it’s still doing the same thing. Please help. Thank you!!!
Welcome to TFP.
What control panels do you have connected to the Aqualink? Do you have a spa control panel outside?
Do you have any indoor control panels or around the pool or spa?
Are the aux circuits that are turning on programmed to buttons on the spa controller?
If so the control panel is going bad. Disconnect the spa control in the main panel and see if it stops. Then replace the spa controller.
