- Aug 15, 2021
- 34
- Plaster
- Saline Generating Systems Breeze 540
Moved from HERE
Sorry to dredge up an old (relatively) post. My water temperature sensor seems to have failed. Getting no reading on the Jandy PDA handheld. The control panel is an Aqualink RS. The air temperature sensor appears to be working fine. Last night, I turned on the spa but since there was no water temperature the heater refused to light. It gave no alarms.
I had to start the heater at the heater itself.
Today, I wanted to swap the sensors in the panel but I cannot get the wires out. My circuit board does not have screws. The wires are held in by a spring-loaded "shield". The empty ones next to it are pretty easy to push in using a small pick, but the ones that have wires I cannot get to budge. My wife was holding the panel while I tried to release the wires.
Anyone seen these connections and have any tips for pulling the wires?
I'm assuming the only option is to replace the failed one, but I wanted to see if swapping would allow normal control of the hot tub. Hoping removing the air temperature doesn't lock the system down.
James
James
