If anyone can help I'd appreciate it.
Last summer was year 1 with my pool. I didn't have any issues -- regular water samples at my local pool store and all was good.
Thus far this year? High chlorine. Low chlorine. PH balancing. Stabilizer. The list goes on.
And now ...electrical or cell issues.... or NOT?
Just as I THOUGHT I had all in order...I noticed something else. And, admittedly, this may not even be an issue but it's something new I've noticed and i wasn't sure if it was normal.
Pardon me if my terms aren't correct. I'm very green with a lot of this.
Issue 1:
Avg salt reading appears fine (3300)
Temp is fine.
Amp (??) is around 27.3
Voltage (??) Somewhere around 4.4
Chlorinator at 28p
Salt intake -3100
But then moments later ....whether it be 5 minutes or 15 minutes .....
Avg salt is still fine.
Temp is fine.
Amp (??) Is 31.4
** Voltage (??) Is 0 (zero)
Chlorinator at 28p
** And salt intake shows as -0 (zero)
Is this normal? To have two zeros on the board? If his happens regularly -- if this happened last year with my pool -- I sure as heck never noticed it. But, perhaps, i wasn't really paying attention to my aqua rite box and all the settings and lights as much as I am now!! Does the cell just turn itself off?
Again this is the AQUA RITE Hayward generator. And my cell is a T9.
The cell (entering its second season/usage) was cleaned prior to the pool being opened a few weeks ago. And there are no lights or warnings showing up on the generator. Everything appears to be fine but I'm thrown off by these zeros.
Issue #2
When not showing zero (!!) ....my intake, as I stated, has been regularly reading -3100 (or -3200) and my avg salt has held steady at 3200 or 3300.
But the water sample I took to my pool store a few days ago ....according to them ...showed chlorine levels in a good spot (2.09) but a salt reading of only 2500.
I've read some posts that say the aqua rite could be off by about 400 ....but 3200 vs 2500!? That's a large discrepancy.
If I'm generating chlorine and my levels are fine .....would that be possible if my salt was actually that low (2500)? And ..........could THIS issue -- with the major difference in numbers -- have anything to do with the first issue I discussed (the zeros)?? Or is there no connection or correlation at all?
Do I trust the generator or the pool store sample reading? I don't want to over-salt.
Again....last year....rookie luck maybe ...I seemed to have very few (if any issues). Now in year 2 ...less than a month in ....I'm confused and paranoid and have zero clue. I've been driven to post here .....which I didn't even feel the need to do as a new owner last year. So clearly I'm rattled and could use some input.
Thanks all. I appreciate the feedback that may come.
Luke
** if it matters, my pool is 26×13 and approx 35,000 litres
Issue 1:
Temp is fine.
Chlorinator at 28p
Salt intake -3100
Temp is fine.
Amp (??) Is 31.4
Chlorinator at 28p
Issue #2
Luke
