A SIRI typo.What is Eskimo?
So, I’m back by the pump now and was just looking to find the screw you were referring to and pulled up on the cover over the pump and it just comes upFan is external, on the back of the pump. Remove the pump cover you have (blue and white) and you will see a shroud over it that is held on with a few screws.
Regarding this particular seller, I noticed it says “This is a genuine cell with a 1 year Hayward warranty” but other sites suggest there may be a 3 year warranty. For example, Hayward’s warranty page seems to suggest a 3 year warranty if bought from authorized sellers - see below.View attachment 511406
is the vendor you linked to not an authorized seller?
Fan shroud is not coming off - screws are stuck - pulled the head off of the first screw trying to loosen it. But, I can reach the fan partially with the pump cover off and the fan spins fine, no noise, and no obstructions between any of the fan blades either. Definitely seems/sounds like the whine is something more major. The whining and ultimate failure of the pump is an issue for another day.
On a positive note regarding salt cell replacement, I was able to get into the Omnilogic settings and find the setting that i would need to adjust to a T-15 cell ($899) if I get that bigger size instead of the T-9 cell ($699)I currently have So that install and setting adjustment seems like something I can do If going up to the T-15 really is the way to go.
Unfortunately, that must be a replacement drive that wasn't installed with the four screws that come with it. They are difficult to install when the motor is out on a bench and virtually impossible with it in place.So, I’m back by the pump now and was just looking to find the screw you were referring to and pulled up on the cover over the pump and it just comes up. See video. Should this be screwed down?
Anyway, about to go back out and unscrew the 4 screws I think take off the shroud over the fan.
