Jimrahbe Mod Squad TFP Expert LifeTime Supporter Jul 7, 2014 33,160 Bedford, TX May 5, 2024 Add bookmark #2 g, You can manually use the valve, if you pull up (or push down) on the valve handle. I can't remember which, and I don't have that style of actuator. Why??? Thanks, Jim R.
G ghreak 0 Jul 26, 2015 27 Lake Elsinore, CA May 9, 2024 Add bookmark #3 Jimrahbe said: g, You can manually use the valve, if you pull up (or push down) on the valve handle. I can't remember which, and I don't have that style of actuator. Why??? Thanks, Jim R. Click to expand... The Actuator is bad and I have not changed it out yet. I found this on Amazon. I’d rather use a Jandy one but I can get this one tomorrow. Have you ever used Tork products? TORK TPE24VA 24-Volt Valve Actuator
Jimrahbe Mod Squad TFP Expert LifeTime Supporter Jul 7, 2014 33,160 Bedford, TX May 9, 2024 Add bookmark #4 I have not used that one, but I suspect it will work just fine.. Cheap enough to just give it a try. Thanks, Jim R.
