I drained my pool and have CYA back on track. What is best way to reduce TA? SHould I add muriatic acid? My PH is in range. Any suggestions would be greatly appreciated.
TA is only a pressing concern when it's causing a problem. Just adjust your pH as necessary and the TA will drop to whatever level allows the pH to be stable.
