- Aug 1, 2023
- 12
- Plaster
- CircuPool RJ-30 Plus
Hello TFP,
Long time lurker, first time poster.
My pool has an Anthony light in it. Built in 1993. The light cycles on and off- every few minutes or so. I pulled the assembly out of the niche just to see the condition. No sign of water in the housing. Transformer tested fine for voltage (12v bulb). So appears this is a bulb issue.
Is this housing beyond safe usability? If not, will any LED retrofit bulbs work in this Anthony fixture?
Local pool guy suggested Spa Electrics retrofit light. Not much out there about them which worries me. Thoughts?
Thank you!
Thank you!
