No more CYA until you get the chlorine under control.Getting there with the FC CC and CYA
FC-.5
CC-2
CYA-50
Adding another 2 gallons of bleach tonight to see if it gets me there. Then I guess it’s back to trying to get TA right and double checking everything else again.
Ignore TA, it's not important.
With high CC and an inability to keep the FC up you have something organic in the water consuming chlorine. You need to follow the SLAM process until it's is complete.
Did I say, ignore TA? The only thing to worry about right now is -
Get pH to 7.0-7.2 You will not test pH again until the SLAM is complete
Add liquid chlorine to get to your SLAM level and keep it there.
Test and add chlorine as many times a day as you can.
SLAM - Shock Level and Maintain
We’ve all had to deal with a green pool. Clear algae from your pool with a SLAM! Read here to use shock level and maintain to clear your pool.
