- Jun 24, 2021
- 16,440
- Vinyl
- CircuPool RJ-60 Plus
Keep at it, The more often the better, no more often than every 2 hours.
Turnover is a myth.turnover of water
I have the intex sx2800.how big is your pool? I see in your signature 4025 gallons is all. Curious what size your pump is as well, my little secret recently was the "turnover of water" per Hayward on gallons and the hours it takes. It sure seems it has helped with everything. Although I question why "Crud" still don't circulate and filter out during those 8-10 hours after a vaccum as well. Example of mine with the picture.
Might be a myth but I can tell you if it's running 24/7 after a manual vac and a robot and Crud is still in there then something isn't working for any turnover.
Not bad. But 1984 was a long time ago. With my personal experience running it as they said don't work for me. Sure maybe since it was so cold and I couldn't brush and vaccum daily was my issue. I don't know. I really wanted the 2-4 hours a day of circulation and running the pump to work but the results proved otherwise.
Just read pages 4 and 5...explains a lot...Not bad. But 1984 was a long time ago. With my personal experience running it as they said don't work for me. Sure maybe since it was so cold and I couldn't brush and vaccum daily was my issue. I don't know. I really wanted the 2-4 hours a day of circulation and running the pump to work but the results proved otherwise.
So page 4, #1...seems contradictory. If agitation is present (pump and circulation) then that would NOT occur with sinking to the bottom of present in those 3 hours. So run the pump more to solve that issue of one is effected, no?Just read pages 4 and 5...explains a lot...
Can you restate your question in another way, I don't understand what you are asking.So page 4, #1...seems contradictory. If agitation is present (pump and circulation) then that would NOT occur with sinking to the bottom of present in those 3 hours. So run the pump more to solve that issue of one is effected, no?
Well today is officially one week with zero change. Not even the slightest hint of improvement. I guess that it could take a week or two with a sand filter but it is now at one week and I don’t have any improvement. I would think I should be showing SOME signs of improvement. Thank you for your help but after the holiday is over I’m putting it up on marketplace to come get it for free because this type of work and expense is not worth it for a pool I can’t even useKeep at it, The more often the better, no more often than every 2 hours.
Don't give up. Whats the zero change you're seeing in person. Do you have any logs you missed. Cya 0 to 40 and FC etc?Well today is officially one week with zero change. Not even the slightest hint of improvement. I guess that it could take a week or two with a sand filter but it is now at one week and I don’t have any improvement. I would think I should be showing SOME signs of improvement. Thank you for your help but after the holiday is over I’m putting it up on marketplace to come get it for free because this type of work and expense is not worth it for a pool I can’t even use.
Yeah you can’t really go by that log because once I got everything where it needed to be I quit adding logs I just kept adjusting the chlorine and seeing how much I needed to add.Don't give up. Whats the zero change you're seeing in person. Do you have any logs you missed. Cya 0 to 40 and FC etc?
All of my numbers are within normal range and have been for several days.Yeah you can’t really go by that log because once I got everything where it needed to be I quit adding logs I just kept adjusting the chlorine and seeing how much I needed to add.
Even though that log is dated today it’s actually from about two weeks ago
Sorry I must’ve missed that.Please post a full set of test results. I requested this last week and you did not do it. Help us help you.
OK I just did a complete test. I’m on my phone so I can’t see how to attach it but can’t you click on my name and view it?Please post a full set of test results. I requested this last week and you did not do it. Help us help you.
