Since assuming ownership of our pool last fall I've done my of my water sampling from the same area of the pool...near a return in the deep end. I get the sample roughly elbow deep. Our pH tends toward the high side (7.8). I'm typically adding acid at least once a week.
On Friday we had a few swimmers over. I did add some acid a few hours before they arrived after a test of ~7.7. On Saturday I happened to take my sample closer to the middle of the pool. pH tested 7.0-7.2. I've never experienced a result this low. I was quite surprised because we even had the waterfall running for several hours on Friday. Looking back I wish I went back and took some more samples but did not. Sunday I took samples from both the deep-end return and the spot I got the low pH reading from the day before. Both samples showed ~7.7
What's the explanation for this? All samples were taken when the pump was running.
