Hi,
I have had success in the past replacing a bulb in my Pentair Amerlite fixture, but this time around I can't get it to stop leaking. I've made sure that all the surfaces are completely clean, definitely using a new gasket, and doing everything according to the manual.
I did use some waterproof silicone sealant around the cord grommet area as well, but I may not have done a good enough job with that, if that is in fact the problem area.
I'm wondering though, if perhaps the tension ring that goes around all the clips and tightens with a bolt and nut can get weak/more flexible over time, and perhaps it's not exerting enough pressure after being completely tightened up. Is this a possibility? Has anyone fixed a leaking fixture by replacing the tension ring?
Thank you,
Greg
Thank you,
Greg
