Is it necessary to drain 6" below skimmer?
Problems I run into:
a winter cover for 30' poo( yes, it says there is 4' overhang but I don't seem to ever have much)l and adding the pillow does not allow the cover to lay on top of water resulting in a taut cover putting significant strain on the railings and walls of pool.
I have ordered a 33' cover, in the past, hoping this would solve the problem but the excess overhang only caused it to catch in the Oklahoma winds and, well.......that idea was no good.
Could I lay the cover on top of water and sink the edges of pool cover in the water and not use the ratchet system therefore nothing to catch wind
Is there a product ( thick , a closed cell foam) used in pool float , that is the same diameter as pool and you lay it right on top of water Blocking sunlight .
I have a deck that goes Half way around the pool.
I've researched shrink wrap and it's not recommended due to the deck.
.Any thoughts????
There would
.Any thoughts????
There would
