Hello all! Longtime lurker first time poster. I have a 2 year old, in ground pebble tech pool. I take care of it myself and have done well overall with the exception of CONSTANT high PH that i still struggle with. I leraned the hard way thanks to this site about the problem with using pool store pucks to chlorinate and building up waaaaay too much CYA. My pool is always sparkling and hass never been cloudy. I run a Dolphin Triton 2 just about everyday so the pool stays pretty clean. I try to brush the walls and steps at least twice a month. I never let anything float or sit on the bottom of the water that doesnt belong there. I am pretty anal about keeping the pool clean. I use a TF100 kit to test my water, again thanks to you guys.
I was hoping you cold help me with a problem that has arose. I have started to get a little green algae on one wall and on a step and a seat where they meet the pool floor. its not much but i cant figure out why I am getting algae it since my last test showed all of my numbers in good range. We have not used the pool for 2 months so swimmers are not an issue. any ideas? Thank you in advance!
here are the readings
FC-1.5
CC-0
TC-1.5
CH-300
TA-120
PH-7.6 (this is after a half gallon of muratic acid two days before)
CYA-58
Does my chlorine need to be higher? I only use one puck in the in-line chlorine disolver becsue i m aleery to use too many since the CYA issues i had. should I put in a gallon of bleach? HELP!
FC-1.5
CC-0
TC-1.5
CH-300
TA-120
CYA-58
