Alkalinity and understanding recommendations in Pool Math
spartyspartan
Active member
Oct 29, 2024
37
Houston
Hi!
I need help understanding where to action on the recommendations in pool math. At the top is says my ph is below ideal range, but also within target. Also my alkalinity is above ideal range but just at the top of the target.
If we ad within target, do we need to action to resolve? Also, what should we use to reduce PH?
Leslie’s recommended that we used muriatic acid weekly. Now that we have switched over to TFP protocol is that still the best recommendation?
TIA for your help!
Forget everything Leslie told you.
Hi!
TIA for your help!
Yes, muriatic acid is what you use to lower pH but you only need to lower it if the pH is above 8.0. There’s no need to do it weekly unless the pH rises over 8.0 weekly.
Reactions: spartyspartan
Ignore the Ideal Range, only look at the Recommended Safe Range.
There is no need to arbitrarily add MA every week. Wait until your pH rises above 8.0, then use Pool Math to calculate the approximate MA needed to lower pH to about 7.4 - 7.8.
In case it is not clear, the "Target" on the bottom is not a recommendation. It is a user input for the calculator to perform the calculation. It's possible to accidently input a bad number in the "Target". Make sure your Target is correct before adding chemicals.
Log you water temperature so you can start tracking CSI
Thank you! What’s the best thermometer for the pool? Looking for recommendations. We don’t currently have one.
Your iAqualink should have a temperature probe I would think. Do you have a pool heater?
Odd. Automation systems use an air temp probe for freeze protection.
His signature says "iAquaLink pool robot".
I think he has a Jandy robot cleaner that connects using the app.
Not Aqualink automation.
Jandy is as confusing with Aqualink as Hayward is with OmniLogic.
Reactions: oledan
Maybe @spartyspartan needs to update their signature with model numbers and replace "iAquaLink pool robot" with "Jandy pool robot".
