My pool is green. We just had our pool deck stripped and re-sealed. So, a ton of junk was washed into the pool water. The water turned cloudy green just after this, and I slammed the pool. The pool was then crystal clear and blue for about a day and then started turning green again, while remaining crystal clear at the same time. The chlorine level has taken DAYS to come down, even with a 0 cya. I did add cya to bring it to 60, but am waiting to add more in case I should slam again. My pool maintenance friend suggested that it could be copper. We checked the pool for copper and it has about .5ppm. Also, we generally struggle with a creeping pH, which is typical, but since the patio was cleaned, my pH wants to be low. It’s currently 7.6, which is fine. I did add borax to raise the pH, since the csi was extremely negative, previous to this current reading. There appears to be some algae growth on the walls when I run my hand on them, ever so slightly slimy and a little cloud forms, and then dissipates. So obviously there is a problem there.
What should my steps be? Slam? Everyone I talk to about it thinks that if my pool is clear, even though it’s green, it wouldn’t be algae. Starting today, I think algae is growing. Also, since the patio cleaning, our spa is making some suds. Not tons, but it’s more than air bubbles since it sticks around in the main pool surface for a bit before dissipating. Also, it really looks like the water itself is green, not the walls and floors.
Should I empty partway and refill? I need help.
Photos attached of current test results, and green pool.
