Just a quick update. It's been a busy weekend. And these trees aren't giving me a break - skimmed the pool 3 times today. Those oak trees are going to get old.
I didn't realize it but apparently we don't have a plunger. I guess we didn't bring one and haven't needed one since we moved. Or else it's packed somewhere (not likely).
So ... I went to try the shop vac, but before I did, I put the dowel in to try to loosen things up, and discovered that it felt a LOT clearer. Still a mass of leaves, but before it was like the pipe was just about packed as far down as I could reach, and almost to the drain opening. So we went to check the pump filter and ... it was packed FULL of black rotted leaves, acorns, etc. I had just cleaned it within the past day or 2. So I think my initial poking around must have loosened it, and the pump ended up sucking it in.
We used the shop vac, and it pulled out some more. It's not 100% clear, but a lot better. At that point, we were running out of daylight.
And I backwashed again, before I read the posts here. It's been I think 2 days since the last time though. The pressure coming out on the backwash was less than usual, and it took a minute for the water to get slightly dirty-looking. It didn't look completely clean, but that could be because the stream looks different with a bit less pressure. It's still a stream the size of the pipe, but before it was a strong gush that has really cut out a groove from the ground.
I think we need to fix the gauge asap. I don't really know what's going on with the filter, and I think I need a better handle on it.
I wish I could say the pool is clean. I think there is no more problem with algae, haven't seen any indication of problems and chlorine loss is much lower. But with all the leaves in the system, and more keep getting dropped to the bottom ...
I didn't get to vacuum today, so I will have to do tomorrow. I'll have a look if I can pick up one of those simple vacuums. There's not too many leaves in the pool, and they are fresh, but there are some. I skim as often as possible, hoping they won't sink.
We still have pollen too, in big fist-sized clumps sometimes.
The trees are just awful. But ... I think our chemistry and water are fine. It's just a matter of getting the plumbing cleaned out and the proper tools for keeping it clean.
Getting there ... !
Thanks everyone!
Getting there ... !
Thanks everyone!
