Algae keeps coming back
Mom2BandK
5
Kentucky
First time poster here!
My pool has kicked my butt all season. I’m about to throw in the towel, but thought I’d come here for advice first. I have gone through the SLAM process a couple of times this summer, and each time passed the OCLT and followed all the other brushing and cleaning guidelines (including cleaning the filter). However, I keep getting spots of what look like algae around the bottom edge of my pool. Today, it’s on some of the wall. These are my numbers today:
FC: 6.5
CC: 0
Ph: 7.5
TA: 80
TA: 80
CYA: 60
CH: 275
My current FC is a tad lower than I like to keep it, but I don’t believe it has fallen below the minimum for my CYA level. If it did, would this quickly allow algae growth?
I know my ph isn’t ideal- could this contribute?
Shouldn’t my CC be elevated with algae present?
mknauss
33,003
Laughlin, NV
Welcome to the forum!
Sorry to hear you have had issues. Your pH is fine. The CC can be zero with algae, they are not directly linked under all circumstances.
Is it the same area that the algae build in? Do you brush that area regularly?
I suggest you read ABC's of Pool Water Chemistry.
Reactions: Mom2BandK
Texas Splash
Welcome to TFP! :wave: Your numbers look good for any normal test results. The pH has no bearing on algae. If your numbers have been that solid, then perhaps there was some algae hidden never found before? Do you have hollow steps, a ladder, niche behind a light, or main drain? All of those can help to hide algae. Might be worth checking.
Mom2BandK
5
Kentucky
Thanks for the reply. I have read the ABCs, but wondered if I missed something. :)
It does always seem to appear around the edge like that, but not necessarily in the same spots I brush at least weekly. 🤷🏻‍♀️
Mom2BandK
5
Kentucky
Thanks for the reply. We swapped out our big bulky steps this year to hopefully avoid an algae situation. Our steps do have grooves, so it’s possible there is some in there. I brush those and when I brush the pool, but maybe I’m not getting them good.
Mom2BandK
5
Kentucky
Oh, also, thanks for the info about the CC and algae! I was a little confused on that. I think I had in my head if CC was 0, then it couldn’t be algae.
Reactions: mknauss
