- May 28, 2020
- 1,235
- Vinyl
- CircuPool RJ-45 Plus
I noticed lots of greenish-brown "dirt" at the bottom again today after vacuuming last night. Dove down the investigate - "poofs" away when I touch it. Thinking it's algae, again, after completing a SLAM 2 weeks ago (met all 3 exit criteria) and battling algae (realized in retrospect) all last year.
Brushed pool, including skimmer throat. Removed ladder and mat.
Added 700ml muriatic acid to lower pH before slam.
Added 2lbs. 65% cal-hypo (had it on hand, vinyl liner, 190 CH). Pool Math says this will add 11.8ppm. SLAM target is 16 @ 40ppm CYA.
Effect of cal-hypo was 14ppm rise 30 minutes after adding to FC of 19.
I have no lights or other nooks for algae to hide.
My question: what do I do with the ladder? During my last SLAM I tied it to the side of the pool so that it was completely submerged and the pipes were completely full. I drained and refilled the tubes several times per day. This time I noticed that each step has a cavity in it that likely doesn't see fresh, chlorinated water very often.
Do I leave it out? How long can algae live out of the water?
Do I completely disassemble and submerge each piece? I would have to cross my fingers it goes back together properly. Pictures attached.
