- Sep 16, 2021
- 189
- Plaster
- Jandy Aquapure 1400
Ok this is a heck of a mess of wires but here in the photos is my best attempt at displaying for you.So if it defaulted back to CLEANER as the 3rd speed, the dipswitch may already be moved to ON.
Do you understanding how the wiring works on the relays? Can you tell if the booster pump wiring is set up to the Lower left relay which is called AUX 1? You would follow the conduit from the booster pump to the cabinet, then follow the wires if they go to AUX 1 relay.
Most booster pumps are 240V, so there will be 3 wires - 2 hot wires to the relay and 1 ground to the ground bar.
You could turn off the circuit breaker to the booster pump first. Each pump should be on its own CB.
You can take photos and post back for guidance.
FYI all my dip switches seem to be in the off position. Photo of that as well as a photo of the buttons on the main board and how they are labeled.
Photo with the faint red circles showing where the two wires from the conduit are hooked up. Photo of the conduit with the yellow circle just showing that is the conduit for the booster pump.
To me it looks as though the booster pump is wired to the Filter Pump Aux and other things are wired to Aux 1. But that is just me looking at these photos and wiring.
Added a photo of the Aux labels from my iAquaLink as well which clearly shows Aux 1 as pool light, Aux 2 as cleaner and Aux 3 as spa light. To me it seems like whoever installed all of this stuff prior to me owning the house clearly did not know what they were doing. FYI there are light switches mounted on the side of my house that can control the lights as well so that conduit is underground but I am sure I could figure it out.
