After the freeze... Swamp Alert!
imrodee
1,050
Waxahachie, TX
Pentair Intellichlor IC-40
Time to bring up the CYA into the SWCG range. Make sure you don't go below minimum with higher CYA cuz at slam it'll require lots of high slam chlorine if the pool ever goes green.
Thank you, I haven’t switched back to salt just yet. I have to figure out if my SWG is working, it’s 9 years old and never been cleaned. It didn’t keep up, so I started on bleach and never looked back. Year 3, I was adding 2-3 bags of salt every week it seemed like. I didn’t know there were ways to adjust the pump to amp up the salt production. :hammer:It will be a couple of weeks before I can concentrate on that. Waiting on the heater to arrive, and the booster pump and digging up 12 ft dead yucca trees. What a mess.
I definitely will be switching back to salt after a bit! Thanks again!
ajw22
24,667
Northern NJ
Pentair Intellichlor IC-60
The pump does not amp up salt production. Salt is only increased by adding it to the water.
Salt is lost along with pool water from draining or splashout.
If you are losing salt then you are losing water.
imrodee
1,050
Waxahachie, TX
wireform
In The Industry
Aug 15, 2017
2,080
Spring Valley, NY
You may just want to bring up the CYA a bit more say 40-50 to protect the chlorine from burning off quickly. The FC/CYA chart will give you the FC target. The chlorine difference is negligible but the gain is huge.
Reactions: imrodee
imrodee
1,050
Waxahachie, TX
To 50? I'm not on salt yet, but I hope to be soon. I have to check out the salt equipment first. Installed 2012, but never seemed to keep up. I was depending on readings from the inside EasyTouch controller.
imrodee
1,050
Waxahachie, TX
Added more MA to reduce FC to decrease TA. I’m working on getting CYA TO 50. I may have stabilizer in the shed in the back 40. Will look tomorrow.
ajw22
24,667
Northern NJ
We are a bit confused tonight. Tough weekend? Ma reduces pH, not FC.
pH of 7.5 and TA of 90 is fine. I would not be messing with it.
Reactions: imrodee
imrodee
1,050
Waxahachie, TX
I meant to say reduce the TA a bit. (Can you tell chemistry was not my strong point in school 1000 years ago?) Thanks for the catch.
imrodee
1,050
Waxahachie, TX
I'm not sure as I looked at the poolmath logs. How do you have on 4/15 TA 60 and 4/18 TA 90.
@ ajw22 Well, today I figured out what happened. You know the cards that come with the T-100 kits? I have an original one and the new one. I didn’t realize the TA instructions and the CH instructions were not in the same order. I’m not sure exactly how I got to “90”, but I’m pretty sure I glanced at the wrong card. I either used the wrong bottle, wrong # of drops or a mixture of both. Operator error. Here I was blaming the wine.... poor wine. :testkit:
