After the freeze... Swamp Alert!
imrodee
1,050
Waxahachie, TX
Pentair Intellichlor IC-40
1:00 AM
FC: 14.5 I'll add bleach to get it up to 16. (I did brush, but not near as aggressively as I should have. (Used my "easy brush").
ajw22
24,801
Northern NJ
Pentair Intellichlor IC-60
1:00 AM
Brushing does not need to be aggressive. All you are looking to do is break the biofilm on the algae so the chlorine can attack it.
Reactions: imrodee
imrodee
1,050
Waxahachie, TX
This morning
FC: 14.5 I added 37oz Bleach (8%) just now.
Can I put the Polaris in the water to soak? I might use him to pick up leaves later. The water is looking really good.
SLAM at the usual SLAM level until you pass the OCLT. Then we can discuss what to do after that.
Are you 100% sure you have mustard algae? Why? Mustard algae is relatively rare, and likes warm temperatures. It's not that hot yet.
I thought the algae looked green/yellow, so assumed it was mustard algae, but maybe not. I'm only going to raise the FC to 16 for now upon 👆 recommendations. Thank you!
ajw22
24,801
Northern NJ
Polaris will be fine int he water if the water looks reasonably clear.
Reactions: imrodee
wireform
In The Industry
Aug 15, 2017
2,099
Spring Valley, NY
This morning
Yeh, let the robot do its thing. Set it to climb the walls too that'll count towards brushing.
imrodee
1,050
Waxahachie, TX
Can I run the robot with the FC at 16? It would probably be just another day of slam, the FC held pretty well today. Tonite:
FC: 15
CC: 1
TC: 16
imrodee
1,050
Waxahachie, TX
The sun got up before I did.. but this morning the reading was:
FC: 15.5
wireform
In The Industry
Aug 15, 2017
2,099
Spring Valley, NY
Slam for another day and do a proper OCLT. When the sun is gone for the day bring it back up to slam level, check it back again 30 minutes later to establish you've achieved slam level. Keep pump running all night and grab a sample before the suns up. I know you're close but with the CC at 1 it still needs a bit more.
Reactions: imrodee
imrodee
1,050
Waxahachie, TX
Will do! Thanks! Pump and robot ran all day (sunny day). I just took a reading, sun is down.
FC: 14
CC: 0
TC: 14
Won't hurt to have it run - I'll add 41 oz to get it back to 16. I'm using 10% bleach now - I sort of had a mix since some stores still have limits. Thanks!
imrodee
1,050
Waxahachie, TX
FC: 16
CYA still 40.
Should I let the FC dwindle down or add MA? (You'd think I'd remember this... not my first rodeo.)
ajw22
24,801
Northern NJ
FC: 16
CYA still 40.
Add MA?? Why????
pH tests are not valid when FC is above 10.
Reactions: imrodee
imrodee
1,050
Waxahachie, TX
Got it... no MA until FC comes down. Thanks for the save.
imrodee
1,050
Waxahachie, TX
I ordered a new heater yesterday, the Mastertemp 400 with the electronic ignition. This one still has bad leaks, pool guy says it’s not worth fixing. 😞. We decided to just replace this one. Just put JB Weld on a very small collar/union (?) that had a crack near the SWG. One of these days we’ll be back to normal!
Finished the slam yesterday am. This morning...
FC: 11
Nothing added yesterday or today.
Reactions: JamesW
imrodee
1,050
Waxahachie, TX
SLAM is over. Here are my readings after 2 days:
FC: 4
CC: 0
PH: 7.5
CH: 130
TA: 80
CYA: 40
Any thoughts on those results? Thank you!
ajw22
24,801
Northern NJ
FC: 4
CC: 0
PH: 7.5
CH: 130
TA: 80
CYA: 40
They look fine. Go swim.
Reactions: imrodee
wireform
In The Industry
Aug 15, 2017
2,099
Spring Valley, NY
Time to bring up the CYA into the SWCG range. Make sure you don't go below minimum with higher CYA cuz at slam it'll require lots of high slam chlorine if the pool ever goes green.
Reactions: imrodee
