So I recently SLAMmed my pool and it seems to have gone well. My TA was a bit low. I raised it from 50 to 60. After poking around in the forum I see that I should maybe work on my pH rather than TA. My pH seems to be hovering around 7.5-7.6. According to the Pool Math app this is “within range” but also high? App says I should be at 6. I have Muriatic acid from Lowe’s. Bottle says 31.5% so I guess I choose the 29% option form the app drop down menu? I’ve learned better to start with less and add more if needed so I’m thinking maybe add a gallon then see what happens. App says add 3 gallons. Just want to make sure I’m on the right track here before I start pouring the acid. Any input, suggestions, confirmations, alarms, etc? Thanks.
