Aerator for 60,000 gallon pool
JPMorgan
695
Elmhurst, IL
Was wondering if any of these aerator products available on the market would be useful to raise pH in a 60,000 gallon pool (see example below). If there are better options, I would appreciate any recommendations. Thanks.
You want to make A LOT of very tiny bubbles.
I used this rig on a sump pump. With it I can raise pH in a 30K pool by .4+ in 12 hours. 1/4" holes (5) in each cap. Wanted to see what happened if I put more, smaller holes in the caps, just never got around to it.
Reactions: Mdragger88
Just Pointing the jets up is free-
There are sprinklers that fit on a return that cost about $20. I have this one 👇
Waterfall Pool Fountain Spray- Adjustable Fun Sprinklers Pool Fountain Pond Fountains Decor for 1.5" Above & In Ground Return Jets https://www.amazon.com/dp/B08TLZ5YX3/ref=cm_sw_r_cp_api_i_CFCX1FT1KQ1HQE5TT67S
There are some with 2 heads as well.
Is this a public pool? If so, unless it’s closed to the public you may not want to put a submersible pump + contraption in with swimmers. The one that has the “air” stick pointing up looks like a hazard for impalement.
Reactions: PoolStored
