PoolMath is just a calculator.
YOU need to give it the info so it can calculate for you.
Just enter your testing results - and try to test at the same time each day.
After a week or so, you'll get a better feeling for how much FC you pool uses each day as the sun's intensity, cloud cover, etc is different each day. You don't log SWG adds - you log FC test results and adjust the SWG accordingly.
There is zero need to micromanage the SWG perrcentage or run time. If the FC gets a little high, that's just fine. It is safe to swim when FC is between minimum and SLAM level for your CYA - and you can see the entire bottom of the pool (swimmer safety).
Just don't let the FC fall below the lower end of the target range - always dose for the high end of the range (or a bit higher if there is a high bather load). And never, ever let FC fall below minimum at any time.
It's just pool water and close is close enough. We aren't making rocket fuel.
Many of us only adjust our SWG every couple of weeks or less. SWG percentage goes up in spring and summer, down in fall. As the temps cool the pool water to 60 or less, monitor to see when the temps are too cold for the SWG to make chlorine - and use liquid chlorine during that time. As temps warm the pool water, turn the SWG back on to start the cycle all over again.
Your CYA is 60 - you need to get the FC toward 9. The FC of 3 your reported is too low. You also reported previous results where FC fell below the minimum of 3. Dose with liquid chlorinne to get to FC 9 and maintain that with the SWG.
What is the pH, TA and CH of your fill water?
You may have already posted that, but I don't want to go thru 50+ posts to find it.
