I currently have a DIY solar system that works sweet all except for it being manually controlled & far too often I forget to turn it off & on (last night lost all heat gain from 2 days prior - ugh). So I'm wanting to add an actuator to my Jandy 3-way valve and a solar controller.
I'm thinking the 'Pentair SolarTouch Solar Control System' at: Pentair SolarTouch Solar Control System with 3 Way Valve | Valve Actuator | 2 Temp Sensors | Water and Solar | 521632
would be the way to go but want to confirm it will work properly with my current equipment, potential future upgrades & would like to hear your recommendations. I called Pool Supply Unlimited but the man I talked with said he wasn't sure if it would work or not & that I should ask a professional installer (he was hard to understand but that could have been due to a bad phone line connection.
My pump is currently a Jandy FLOPRO #FHPM1.0 (I've had to replace the capacitor on it twice so I'd like the solar controller to be able to work with a future quieter variable speed with slightly more power).
The pump timer is an Intermatic Model: T104R with a 24 hour daily time switch.
Would the SolarTouch controller & the actuator be wired to the pump timer or the pump itself?
Is Pool Supply Unlimited a reputable & recommended place to buy from? Or would you recommend someone else & who?
