I have an E65 system with the fingers and after I bump it, are you supposed to wait at all before you turn the pump back on? I usually bump it 6-8 times, then when I turn back on you can sometimes see a little DE out of the one return, and this same return has some air bubbles coming out of it. Not bad, but it's been this way for a while. Other return futher away, no bubbles...
