Hey guys,
So I just installed my double roman, steel wall and vinyl liner inground pool. We did it all ourselves with the help of a friend in the industry and family/friends with the right equipment. The pool came out great and we've been enjoying it during quarantine and this hot summer.
I made a big mistake in not planning out lights during the purchase process and want to add some now.
I've done a lot of research and purchased a pooluxe premier from sr Smith and 4 of their mod lites to add. I purchased the proper light housings which require a 3 and 1/8" hole in the steel wall for installation. There is no decking around the pool yet and now would be the time to do this retrofit.
I can find no videos or tutorials of anyone online draining their pool water to the necessary level and then drilling through the liner and steel plate.
These lights are all plastic and only need to be 4" below the waterline not the standard 18". I plan on putting them in line with my returns. I'm planning on lowering the water level to a comfortable level say 4 more inches or so below the install points and then using a metal 3-1/8" bit on a cordless drill to cut through. I would first mock it up on the liner, cut the liner out slightly larger than the necessary 3-1/8" and then cut the hole.
Is this impossible? Do I need to drain the entire pool and remove the liner to do this? Am I over thinking this? Sr Smith feels drilling a hole is not a big deal as long as I'm comfortable with the drill. I'm mostly worried about the liner being ruined during this process and am looking for some advice.
Thank you!
Thank you!
