This has started happening again just now this season, and it also happened last summer about partway through the season. One day everything is normal, and then the next time I add chlorine, I can see it forming a visible white cloud as it moves trough the water. It doesn’t dissipate quickly either, it stays. It will go away for the most part after a day or two, either by the filter catching the “cloud”/precipitate or the chlorine levels dropping back down.
Anyone know what might be causing this? Here are my levels (Taylor 2005 test kit, fiberglass pool, no SWG):
PH 7.4
CH 250
TA 70
CYA 50
My FC was in the 1-2 range so I added enough to get it to the 5-10 range, and now the pool is cloudy white. I can still see the bottom of the deep end, but ?.
The only other thing in the water is Proteam Metal Magic which I use to combat some pretty decent staining. I added quite a bit at the start of the season but haven’t put any more in since. Adding chlorine produces the same white cloud as when the MM is first working. Could it be causing the metals to come out of solution, or...?
PH 7.4
CH 250
TA 70
CYA 50
