Adding Auto Fill Valve
As a prototype that’s not a bad effort but using clear primer and glue would make it look a lot better. If it’s connected via a garden hose leaving it on full time is a bit of a worry. Eventually the garden hose connection will fail if left permanently presurised.
It wouldn’t be to hard to make one from bits from a hardware. I’ve made one in a square shape using a side entry toilet valve. I use a battery operated timer tap to limit the possibility of failure. I give it 20-30 minutes per day.
There are commercially available options.
I based my design on this one.
