PoolMath calculated that my volume is around 29,000, but I am not getting the estimated chemical responses based on PoolMath's recommended chemical dosages. Here is the most recent chemical addition data:
1) At 5:50pm the FC was 4.5 ppm.
2) 511 oz of 10% sodium hypochlorite bleach was added at 6:26pm
3) The FC was remeasured at 6:56pm and was found to be 15.5 ppm
Notes: The sun was not shining. The pump was circulating.
I fed this along with other data to some LLM's and they are spitting out that the volume is likely around 36,000 gallons. Does this seem correct?
Here is other recent data exported from PoolMath. All bleach was 10%. Muriatic acid was 31.45%
Build Type: Plaster
Volume: 28912 gallons
Chemistry: Liquid Chlorine
Latest Test Result Summary:
FC: 15.5 (1 hour ago)
pH: 7.5 (1 hour ago)
TA: 70 (2 hours ago)
CH: 250 (2 hours ago)
CYA: 50 (1 hour ago)
TEMPERATURE: 74° (2 hours ago)
CSI: -0.43 (1 hour ago)
Test Results 06-04-2024 @ 07:06 PM
CYA: 50
CSI: -0.43
Test Results 06-04-2024 @ 06:59 PM
pH: 7.5
CSI: -0.38
Test Results 06-04-2024 @ 06:55 PM
Free Chlorine: 15.5
CSI: -0.80
Chemical Addition 06-04-2024 @ 06:50 PM
+ 8 Pounds of CalciumChloride
Chemical Addition 06-04-2024 @ 06:26 PM
+ 511 FluidOunces of Bleach
Chemical Addition 06-04-2024 @ 06:12 PM
+ 46 Ounces of DryStabilizer
Chemical Addition 06-04-2024 @ 06:04 PM
+ 65 Ounces of Borax
Test Results 06-04-2024 @ 05:50 PM
Free Chlorine: 4.5
pH: 7.0
Total Alkalinity: 70
Calcium Hardness: 250
CYA: 33
Temperature: 74°F
CSI: -0.80
Chemical Addition 06-03-2024 @ 05:43 PM
+ 1 Gallons of Bleach
Test Results 06-03-2024 @ 05:21 PM
Free Chlorine: 6.5
pH: 7.2
CYA: 25
Temperature: 70°F
CSI: -0.67
Test Results 06-03-2024 @ 07:31 AM
Free Chlorine: 15.0
Calcium Hardness: 200
CSI: 0.16
Chemical Addition 06-02-2024 @ 07:06 PM
+ 327 FluidOunces of Bleach
Chemical Addition 06-02-2024 @ 05:29 PM
+ 8.6 Pounds of CalciumChloride
Chemical Addition 06-02-2024 @ 05:19 PM
+ 3 Gallons of Bleach
Chemical Addition 06-02-2024 @ 05:02 PM
+ 29 Ounces of DryAcid
Chemical Addition 06-02-2024 @ 05:00 PM
+ 133 Ounces of BakingSoda
Chemical Addition 06-02-2024 @ 04:53 PM
+ 171 Ounces of DryStabilizer
Test Results 06-02-2024 @ 01:58 PM
Free Chlorine: 0.0
pH: 8.2
Total Alkalinity: 50
Calcium Hardness: 150
CYA: 0
Temperature: 70°F
CSI: 0.04
Build Type: Plaster
CYA: 50
CSI: -0.43
pH: 7.5
CSI: -0.38
Free Chlorine: 15.5
CSI: -0.80
Free Chlorine: 4.5
pH: 7.0
CYA: 33
Temperature: 74°F
CSI: -0.80
Free Chlorine: 6.5
pH: 7.2
CYA: 25
Temperature: 70°F
CSI: -0.67
Free Chlorine: 15.0
CSI: 0.16
Free Chlorine: 0.0
pH: 8.2
CYA: 0
Temperature: 70°F
CSI: 0.04
