I need to do a partial drain to reduce CYA and just got my well water test back. Is this ok to directly fill the pool with? I am assuming the previous owners just used hose water and it looks ok. There is a softener in the house, though I'm not sure it would be ok to pull 10k gallons through it. TA is high, not sure how much of a process it would be to lower that much with acid/aeration. Iron is just under 0.3ppm, which is hopefully ok.
pH 7.9
Total Dissolved Solids (TDS) Est, ppm 290
Electrical Conductivity, mmho/cm 0.48
Cations / Anions, me/L 4.8 / 4.4
ppm
Sodium, Na 5
Potassium, K 4
Calcium, Ca 54.6
Magnesium, Mg 21
Total Hardness, CaCO3 225
Nitrate, NO3-N 6.1 (SAFE)
Sulfate, SO4-S 3
Chloride, Cl 3
Carbonate, CO3 < 1.0
Bicarbonate, HCO3 226
Total Alkalinity, CaCO3 186
Aluminum, Al 0.05
Silica ,SiO2 31.7
Total Phosphorus, P 0.04
Zinc, Zn < 0.01
Total Iron, Fe 0.02
Manganese, Mn < 0.01
Copper, Cu < 0.01
Arsenic, As (Total) 0.0015
Cadmium, Cd (Total) < 0.0001
Lead, Pb (Total) 0.0009
pH 7.9
ppm
Sodium, Na 5
Potassium, K 4
Calcium, Ca 54.6
Magnesium, Mg 21
Sulfate, SO4-S 3
Chloride, Cl 3
Aluminum, Al 0.05
Silica ,SiO2 31.7
Zinc, Zn < 0.01
Total Iron, Fe 0.02
Copper, Cu < 0.01
