- Jun 24, 2021
- 15,964
- Vinyl
- CircuPool RJ-60 Plus
Yes, that is a sand filter. No, you will only see what in sight glass when backwashing or rinsing.Almost positive it is a sand filter now. Attached some pics for you to check out. Searched model number and pulled up valve for sand filter.
While I was trying to find the model number, I realized I did have a window to watch the water while backwashing. Should it be full of water? Got a pic of it for you to check out too!
I would hold off on the clarifier for now. If you end up going the clarifier route, do not use a polymeric clarifier...it will gum up your filter. Clarifiers have some use in pools, but they are no better than adding DE to a sand filter and should never be used with cartridge or DE filters. I would follow these instructions and use DE in your filter to aid filtering. Follow the instructions. DO NOT use Garden DE. Use POOL DE.
Add DE to a Sand Filter
A clean pool filter will increase the efficiency of your pool! ... your filter are to backwash it, clean the manifolds and grids, and add new DE.
