- Jul 17, 2016
- 515
- Plaster
- Hayward Aqua Rite (T-15)
I have an aboveground pool that I want to add a CircuPool RJ-45+ SWG . The plumbing is very accessible, and I can place a post in the ground to mount the RJ control box. The problem I am running into is that my pump is a two-stage pump (Pentair Optiflo 1.5hp) that is plugged directly into a 110v outlet and is run 24/7 on low. I have 3 more 110v outlets available at the installation site (see picture).
My question deals with the electrical hook-up of the CircuPool RJ45+. Is it possible to configure the RJ45+ so that it can be plugged directly into a typical outlet so that I can use my electrical setup as is? If the RJ cannot be plugged directly into a regular household outlet, what will I need to do to get power to the RJ given that I only have 110 run to the pool and there are no timers being used?
