- Nov 12, 2017
- 12,639
- Plaster
- Pentair Intellichlor IC-40
Re: Above Ground Pool Size & Depth
Right. Got that. What I am suggesting is that they use a few pieces of PVC and some PVC fittings to redirect the return lower in the water, to keep it from splashing on the surface. They might have to replace the existing port to be able to mate it to PVC, but they wouldn't have to cut the second hole. When the boys grow up and they can restore the original port, they won't have that second hole to live with.
It's just another way to go about it... I'm not sure which way would be easier to put together, but if I could solve this without cutting a hole in my new liner, I would...
It's just a matter of finding the right parts at a pool and/or hardware store.
Should work now.
What I was suggesting was to close up the original return fitting, and cut a home for a new return fitting that's lower down.
