Water is perfectly clear! Should I pull the sock out or leave it in?
For the test schedule, see the Basic Pool Care Schedule page in Pool School.How often should I test everything? What should I test daily?
For the pump run times, see the Determine Pump Run Time page in Pool School.HHow often should I run the pump daily?
The easiest thing to do is to bring your FC level up to SLAM level right before you leave. Then you could have a friend / neighbor stop by every other or third day and add a half gallon on bleach. That would hold you over nicely until you return. FC will drift down but still be well above your minimum FC level when you return to nice clear water. Leave your pump run 24/7 if its not on a timer.Also... I'm leaving for vacation Sunday and coming back the following weekend. I have someone that lives close that could help with chemicals but not able to test. Should I have them put in half gallon of bleach daily? Anything else I should have them do? Let the pump run 24/7 while I'm gone?
